Pls help! TRX40 Asus Strix XE Big Sur
Blehzinga
Hi guys,
I've been trying to install big sure on my rig specs are
Ryzen TR 3970x
Asus TRX40 Strix XE
64 GB corsair vengeance ram
Samsung 980 1TB NVME SSD
GT 710 for installing I have vega 64 and 6700XT also.
Basically I've installed it successfully multiple times on x570 but this TR is being impossible.
Steps taken so far
Multiple fresh USB installs
followed open core guide directly
Saw that @Cosmin already had a TRX 40 Strix E EFI and config file so used that also.
Basically, the installer goes fine I select dmg and then move to format the drive and start installing Big Sur.
Post this is where the issue starts instead of restarting and continuing with installation so on 3rd boot is ideally suppose to be able to select the ssd to boot off instead of pen drive.
but in my case, it finishes the install reboots and starts the process from scratch again and it's an endless loop of that with no next step.
Any pointers would be appreciated.
My Efi is attached for reference
Blehzinga
Basically my issue is that after the first reboot the MACOS installer option doesn't come.
