Please need correct EFI
Nikotetfe
20
Canary Island
hello everyone. first of all thank you very much for the help. and sorry for my english.
I've been trying for days to create an efi for myself but I'm getting worse and worse.
If someone can help me please.
this is my hardware and my efi. my intention is to install sonoma.
Asus Tuf Gaming b550m PLus
Ryzen 5 5600x
rx 6650xt
ssd
thank you very much
    EFI.zip
I downloaded the EFI folder and set it up for my hardware. I have Sonoma installed but I can't get my rx6650xt to have graphics acceleration.
The sound works fine and I also have internet connection.
I can't get the graphics card fixed.
Can you help me to verify where is the failure?
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>DeviceProperties</key>
<dict>
<key>Add</key>
<dict>
<key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x1)</key>
<dict>
<key>compatible</key>
<string>pci8086,a182</string>
</dict>
<key>PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x2)/Pci(0x4,0x0)</key>
<dict>
<key>device-id</key>
<data>BqgAAA==</data>
<key>vendor-id</key>
<data>TRQAAA==</data>
</dict>
<key>PciRoot(0x0)/Pci(0x3,0x1)/Pci(0x0,0x0)/Pci(0x0,0x0)/Pci(0x0,0x0)</key>
<dict>
<key>framebuffer-patch-enable</key>
<data>AQAAAA==</data>
<string>pci1002,73EF</string>
<data>7O8AAAA=</data>
<data>gQAAAA==</data>
<key>model</key>
<string>AMD Radeon RX 6650 XT</string>
</dict>
</dict>
<key>Delete</key>
<dict/>
</dict>
</dict>
</plist>
Very thanks!!
    EFI.zip
Change the RX 6650 XT's DeviceProperties > device-id from <ECEF0000 00> to <FF730000>
Remove or Disabled the SSDT-6650.aml table, as you don't need both elements in your OC setup. Plus the SSDT doesn't look correct for an AMD system.
