Please help!
CodingMaster1254
AMD Ryzen 5 3500U
Hello guys,
I need help with installing macOS.
So I made a USB installer of macOS High Sierra, and I booted it.
I wiped my hard drive as MacOS Extended Journaled and I installed to that partition.
This first part went fine:
Then I rebooted to the USB and back to the installer, and ran preinstall command from Terminal.
After that, I rebooted to macOS installer.
When I did that, a problem happened:
It said "The file /System/Library/Installation/Packages/OSInstall.mpkg is missing or corrupted":
Please, I need some help, it would be appreciated!
Which tutorial did you follow?
