Please help me, I need your help!
rmae006
Czech Republic
Ryzen 9 9900X
I need to create an OpenCore EFI config.plist for a new build.
I can't make a new configuration.
I have a Ryzen 9 9900X processor.
Motherboard from Asus, model ROG Strix B650-E-F Gaming WIFI
I don't have a graphics card yet.
Please help me in creating an EFI for my components with the right components inside, so that everything will run without problems without errors and hangs.
Thank you all in advance!
Your hardware is fine but you’ll need a supported AMD graphics card to be able to use macOS being the iGPU on the AM5 processors is unsupported. It’s just not worth trying until you get a supported GPU
My processor supports integrated graphics and my system shows the image without a graphics card.
And as I wrote, I need to build an EFI folder with all the components to run macOS without errors and flaws. :rolleyes:
No, because your CPU’s integrated GPU isn’t supported in macOS.
