Hi everyone,
I have a build using Asrock TRX40 Creator, 3970x, DDR4 RAM, 2TB Sabrent 4 NVMe SSD and Asus nVidia GeForce G710 1GB GDDR5,PCIe graphics card (metal compatible) as its a workstation build.
I have being trying to install using OpenCore 0.7 but I keeps crashing with 2 minutes to go, boots OpenCore fine and obviously installer starts - apparently this relates to NVRAM and I have tried to disable 4G coding but same problem + the trouble shooting steps suggested in the Dortamia guide under 'user sopace issues' relating to this. Done the sanity check on config.plist and checked kexts etc.. and all is in order.
Additionally I have used SSDTime to create custom .aml files. So I am stuck, I have tried High Sierra and Catalina with identical results.
If any experienced forum members read this any advice would be appreciated! thanks
PS My bios is also up-to-date.
