Developer from all over the world, are you ready? Still needs some patches to my fully working RPL-P laptop but... it's open to developer now.
No more IOPCIPrimaryMatch, we work on IOResource so just put your kexts in /Library/Extensions folder or use /System/Library/Extensions kext
IOResources solving now is done like this for TGL or IcL : first look at LE kexts and if any kexts is found than fallback to find in SLE kexts
https://github.com/sgiammori/NootedGreen
Boot args advised for testing (build togheter my forked lilu sources as release version not debug) (Hookcase in /Library/Extensions/ too) :
-v keepsyms=1 debug=0x100 IGLogLevel=8 -NGreenDebug -liludbg liludump=60 ngreen-dmc=skip -allow3d -disablegfxfirmware -ngreenAllowMetal (and as optional= "ngreenSched=N", 3 = GuC firmware, 4 = IGScheduler4, 5 = host preemptive (default: 5) )
they need permissions fix so before move to /L/E do in some random folder (maybe better use our Lilu plugin forked for IOResources eventually problems...
Workflow:
(maybe necessary this below also)
sudo kmutil load -p /Library/Extensions/AppleIntelTGLGraphics.kext 2>&1
sudo kextcache -i /
Here our forks also STILL in development... but we are very close to FULL implementation.
Thanks to @shl628, @jalavoui, developer of NootedBlue, Claude Sonnet, Claude Opus copilot interpretes..
(Here you can find kexts... and our ready to be used fork of Lilu (still in development too)
Just use double kexts each time (Framebuffer + Graphics)
Workflow:
- chmod -R 755 test/Apple*
- chown -R root:wheel test/Apple*
- move the files to /L/E
- delete /Library/KernelCollections/AuxiliaryKernelExtensions.kc
- redo chown -R root:wheel /Library/Extensions/Apple*
- sudo kextcache -i /
sudo kextcache -i /
This is a new project - currently the tgl framebuffer loads on some systems read about it here Updated source code https://github.com/macintelk/drm
www.insanelymac.com
