No internet connection with LucyRTL8125 kext in Tahoe Recovery
Astral420
Ryzen 7 7700
Hi, I do not get internet connection when trying to install Tahoe on my system with this ethernet kext. I used this version of the kext since I am using AM5.
And here are my specs.
Ryzen 7 7700
Asus B650M-AYW WIFI
ASRock Challenger D RX 6600
BiWin DW100 DDR5 32 GB
I do tend to have some kernel panics or sometimes black screens but that isn't really an issue since I tend to reset NVRAM from time to time it happens. Hence I was able to go into MacOS Recovery anyway.
I attached my EFI as well.
I would recommend you enable AMD Kernel Patch #18, which is aimed at fixing PCI bus issues on AM5 systems, like your B650M board. Enabling this patch might help with the issues you are facing.
Screenshot 2025-12-13 at 16.03.15.png current setting for patch #18
Screenshot 2025-12-13 at 16.03.00.png revised setting for patch #18
You don't need to use -lilubetaall boot argument in your config.plist, as Tahoe is no longer deemed a Beta release.
Screenshot 2025-12-13 at 16.09.30.png Boot Args, remove those not required
You have alcid=1 in your boot args, plus an entry for an Audio layout in your DeviceProperties. As you don't appear to be using the alternate AppleALC.kext which is required for Tahoe.
Screenshot 2025-12-13 at 16.07.02.png DeviceProperties section, should be empty.
Also when using NootRX.kext you should not be using any DeviceProperties in your config, as they can cause unnecessary issues when booting macOS.
I have attached a revised EFI folder below, this includes the issues mentioned above plus I have cleaned up your config.plist so it is easier to read and navigate.
Try it on a spare USB pen drive and see if it helps.
Reactions: Astral420
Mkay I'll try it, thanks!
View attachment 18536 current setting for patch #18
View attachment 18535 revised setting for patch #18
View attachment 18538 Boot Args, remove those not required
View attachment 18537 DeviceProperties section, should be empty.
Soo it did end up on a kernel panic first try but I ended up resetting NVRAM anyway and that fixed itself booting to recovery. However I still don't get Ethernet in Recovery
EDIT: I'll probably scour around and try a different version of this kext but it's pretty dim.
