No audio with AppleALC.kext (ALC887). Tried every alcid bootflag
CameraObscura
Hey guys,
I'm having problems having AppleALC setup correctly. I have a Ryzen 5 2600 CPU paired with a Gigabyte B450M-S2H which uses a ALC887 codec.
I can only get sound using the VoodooHDA kext. I make sure I properly uninstalled VoodooHDA before trying AppleALC.
I tested every alcid=x bootflag but to no avail.
I'm using a vanilla AppleHDA as well.
Attached is what appears in my IOReg.
Any help or directions would be appreciated.
I have solution install ALC887 and VoodooHDA don't install AppleALC you have same sound card like main. Is not to bootflag just you need right kext for you.
ALC887 is sound kext, VoodooHDA is like GUI interface. But in Win 10 before sound signal is more higher more loud from OSX
Download kext from below.
Screen Shot 2020-08-15 at 03.40.58.pngScreen Shot 2020-08-15 at 03.40.37.png
