Network problems, resize bar and optimization (Asus z570-F, 6900 XT, Ryzen 9 5900x)
JRevenge7
Concorezzo (Italia)
Ryzen 9 5900X - Asus Rog Strix x570-F - Dominator Platinum 32GB DDR4 - NVME 980 Pro 1TB
Good morning to everyone and especially to those who will help me,
I am having problems in the latest OC updates with my configuration, especially the latest one and I need your help.
In particular:
- Since I activated the resize bar (to be able to activate S.A.M on Windows) I have encountered problems in the latest versions where very often the PC does not start, but returns to the BIOS, after many times I click, it starts. I also tried a clear NVRAM but with little success. Video with verbose and problem
- The internal network card, unfortunately, has problems and with Monterey if I keep the WiFi active together with the network card, it freezes and the PC restarts (with WiFi it does not give problems being an external network card)
- I ask, if possible, an optimization of the system, as it works well, but in my opinion it can be improved and above all usable in the best way.
Thanks a lot to those who will help me!
Attached is the OpenCore EFI with the current build and I am also attaching the video of the error that is created.
