Need installation advice
xello
AMD Ryzen 5 5500
Hello everyone Ventura used to be there and everything was fine, but there was a need to install Sonoma. I can't build / find a config for my system in any way. Maybe someone can suggest or give a ready-made config? I will be very grateful!
Specifications:
AMD Ryzen 5 5500
Aorus b450 elite
16gb of RAM XPG DDR4
AMD RX 5600 XT
I also attach my current config working with ventura
Specifications:
AMD Ryzen 5 5500
Aorus b450 elite
AMD RX 5600 XT
Please try the attached, Opencore, Kexts and AMD patches updated
Thanks for your precious answer, but using your configuration I see the following
Hmmmm, please zip and upload your existing EFI for more help. The config.plist by itself isn't sufficient to understand any issues, its only half the puzzle.
Specifications: mapquest driving directions
AMD Ryzen 5 5500
Aorus b450 elite
AMD RX 5600 XT
I appreciate your thoughtful response, but based on your arrangement, I see the following
