- Joined
- Jan 8, 2022
- Messages
- 6
Hello.
I'm new here in this forum and I need help for my Hackintosh.
I had Big Sur installed with OpenCore 8.2 (newest Version). Everything worked fine. Then i decided to update to Monterey.
After updating my Kexts, everything exept WLAN and LAN worked.
For WLAN, I tried airportltlwm and ltlwm with HeliPort, but both didn't work (HeliProt says itlwm is not running).
For ethernet, i attempted to use smalltreeintel82576, but no luck. I also tried AppleIGB, but also no luck.
I don't even see anything in the Settings in the Network Preferences, not even after a reset like mentioned here: https://openintelwireless.github.io/itlwm/Troubleshooting.html.
Wifi, Lan and Bluethooth all don't show up. (With AppleIGB, theres also nothing in the Network Preferences).
Clicking on the + or Creating an Envirement results in the Network Preferences closing and it giving me an error message.
Screenshot showing that the Kext is loaded and my problem attached below.
My EFI is also attached below.
My system specs are in my signature below the EFI attachment.
What could I do to get an Internet Connection?
