I need your help.
My last build with this setup (my sig) wasn’t that great.
Can someone help me to build a solid version to run in dualboot with Win11?
Try this OC 0.9.1 EFI. I created the EFI for another member using a X570 MB and 8-core CPU. But I have adapted it to better suit your ASRock MB and RX5700XT dGPU.
You need to add the MLB, ROM, Serial Number and SystemUUID to the Generic section in the config.plist. Do this before you try to use it.
You should use either an iMacPro1,1 or a MacPro7,1 SMBIOS with your system.
