Need help solving computer shutdown / restart
viksanich
Беларусь
Ryzen 3600
I ask for help! I started installing the hackintosh for the first time! Everything worked out well, everything works except shutting down the computer! It turns off for a second and starts again! I tried to do as in this link -https: //dortania.github.io/OpenCore-Post-Install/usb/misc/shutdown.html but for me it's a dark forest and I'm not sure what I did right! Therefore, a request to those who understand, check my files, if everything is correct there! If not, tell me how to do it right! Thank you in advance!
Check your BIOS settings. See if you've got an option similar to Power On By PCIe. If you do then Disable it.
Hey friend, I found this option and it is disabled!
