Need help setting up tahoe on my threadripper 3960x paired with asrock taichi trx40
aamirkhn
Amd Ryzen threadripper 3960x
Any sort of help will be appreciated. Fairly new to hackintosh. 1st build on amd. Not posting major details. If someone could guide me will share the details asap. Tried using open core simplify but gets stuck at 12 minutes. Tried making my own efi not even reaching disk utility.
Getting stuck here
Post a copy of your EFI folder, so we can see what you are using.
Try creating a new USB installer, as the macOS installation app you have downloaded may be borked.
You need to delete the macOS installer you previously downloaded.
Do not use the same installation app you previously downloaded as it will just get you back to the same point in the process.
Ae you using the online (Windows) or offline (macOS) method when creating the macOS installation USB?
