do you mean you are instaling from an USB pen to another USB pen?I have two drives i bought for the needs of installation. To be frank I don't know the exact model. Do you recommend any specific model for this reason?
Check if algrey/shanee fix pat patches are fine and try to disable whatevergreen kextMost likely the problem is in the SSD. I using a spinning HDD because I don't have another one to test with. I was able to install Sequoia in the end, but the installation did not find the network card and PC was very slowly. My monitor uses DP. The problem I am facing is that after copying the EFI to the main drive Mac OS is unable to boot and show yellow screens on boot. Regarding the SSD drives what do you think about Kingston FURY Renegade NVMe/M.2?
Post only your latest config.plistThank you guys.I am so happyAfter so many failed attempts I was able to install my Sequoia successfully. Fabiosun I followed your final advises and now there is no green/yellow screens, but now I am facing o couple of issues I have to to solve:
1. I am using 32GB 5200 MHz DDR5 not 3200 as it written. How can i change this
2. Audio Realtek LC1220 CODEC is not working
3. Lan Realtek® 2.5GbE LAN chip (2.5 Gbps/1 Gbps/100 Mbps) is not working
4. Wireless Communication module Realtek® Wi-Fi 7 RTL8922AE (PCB rev. 1.1) is not working
Please help me to make them working. Thank You!
from your gigabyte bios memory section you can force your ram to that speed. if your system boots fine and it is stable you see them also in OSX @52001. I am using 32GB 5200 MHz DDR5 not 3200 as it written. How can i change this
added in your config bootarg alcid=5Post only your latest config.plist
kext used for your ethernet should be the right one (but i do not well if it is compatible with sequoia)Post only your latest config.plist
try to read here:Thank you. I already have sound but not LAN. Do I need any kext for this? These are the specification of my motherboard
X870 AORUS ELITE WIFI7 Specification | Motherboard - GIGABYTE Global
Lasting Quality from GIGABYTE.GIGABYTE Ultra Durable™ motherboards bring together a unique blend of features and technologies that offer users the absolute ...www.gigabyte.com
about ram i have answered above (only from bios if you have set them in autoReally disappointing to hear that. What do you recommend? I can't work withowt a LAN. About the memory I am using 32GB 5200 MHz DDR5 not 3200 as it written. How can i change this?
