need help, been trying for 3 days..
sizar
Ryzen 5 5600x
Hello guys im trying to install tahoe 26.1 and everything is setup, when i reboot the pc and select the "install macos tahoe" from the oc bootloader it writes about 26 lines and stops at #[EB |LOG : EXITBS :START] , i tried all the troubleshootings in dortania website but i cant get the hang of it please help thanks.
cpu: amd r5 5600x
gpu: amd radeon rx 6800 xt
motherboard: gigabyte b450m ds3h
    EFI.zip
cpu: amd r5 5600x
Hello @sizar .
If you are wanting to install Tahoe its necessary to remap your USB ports, USBToolbox and UTBMap.kext are not compatible in 26. USB functionality has changed and older kexts aren't formatted correctly and so will not work. You can try using either CorpNewt's excellent USBMap Master or Hackintool as both have been updated to accommodate the changes. You'd have to do the in Sequoia though.
Make sure you have OpenCore and your Kexts Updated to the latest versions.
Also disabling Whatevergreen.kext is often needed until install completes, but you also should par down your EFI to just the basic kexts. Bluetooth and Ethernet should be disabled again until install completes. Good Luck!
Reactions: sizar
Hello @sizar .
Hi, thanks for the clarification, that was with the tahoe raw file, now im trying to install sequoia with the recovery method and still dont have any luck with it, this time its a clean efi and config only the necessary files and kexts, it just stuck on the motherboard background/logo after selecting the UEFI: Flash Drive from the bios.
edit: i just edited this reply so i could upload the new efi folder thats for the sequoia recovery method
