Motherboard replace
Nestovsky
Few days ago my MB Died (Asus Tuf b650 plus wifi) and I bought new (Asus rog b650e-e). Now it doesnt start with my previous efi. What I should change?
  • EFI.7z
leesurone
Usually the Booter/ MmioWhitelist values own the config.plist differ from Gigabyte to Asus. If you have updated the bios that allows the 8000 or 9000 series processors to run it gets more complicated. What version bios are you running?
Nestovsky
the last one 3024
Nestovsky
Thx, I installed Bios 1413 and it works now
fabiosun
@Nestovsky
it is possible to use also latest ASUS bios with 8000/9000 CPU support
It is mandatory to patch DSDT in ACPI section of your config plist
@CorpGost from AMD-OSX Discord server can help to debug the patches you need for it
