I have posted this in another forum, perhaps I could get more traction here in AMD specific forums - hopefully this isn't a breach of any rules. Happy to remove the post from the other forum if it offends anyone. I am merely doing my best to ask questions...
Mb: Gigabyte B550i Aorus Pro AX
Processor: AMD Ryzen 9 5900X 12 cores
RAM: 32GB 3200 MHz DDR4
GPU: Asrock Challenger Series Radeon RX 6600 XT ITX Series 8GB
OC version: 1.0.1
I am trying to migrate a Monterey (Z690 intel) install to my AMD hardware as my Z690 hardware is dead
I would like to update the installation to Sequoia, if it doesn't work, I'm willing to do a fresh install, but it would save me a lot of time and trouble as many of the software I use have to be re-activated and settings to redo.
First AMD ryzentosh - followed through Dortania's guide and made a few different config.plist as each of them failed, unable to past boot.
Out of desperation I found other's EFI of the same mobo, updating the core counts, checked USB mapping. Still stuck at the same point. Checked BIOS settings, just wouldn't boot, regardless it was my own plist or someone else's....
Today I made another attempt, and by coincidence turned on "SetupVirtualMap" to enabled, the exisiting Monterey install was able to boot into OSX login screen, but will crash within a few seconds of login. I understand this flag is to be disabled for B550 chipset. So I am really baffled as to why I could boot past the initial stage. Disabling the flag will get stuck at the same boot sequence before kext are loaded.
I have attached 2 different versions here (second one is after I have made attempt to tidy-up and mistakenly enabled the flag)
Please HELP!
OC version: 1.0.1
.I would like to update the installation to Sequoia, if it doesn't work, I'm willing to do a fresh install, but it would save me a lot of time and trouble as many of the software I use have to be re-activated and settings to redo.
Please HELP!
