Microphone doesn't work, Big Sur upgrade
barkata0x
5
Hello,
Recently I have installed Hackintosh Catalina, upgraded to Big Sur.
Using AppleALC kext, audio works fine, but so doesn't the microphone.
Does anyone know a fix for the microphone in Big Sur?
Thanks.
RIG:
Ryzen 5 3600
RX 580 8GB
TUF B450 Plus
Mic in is a known issue with AMD hacks. I use a USB mic with no problems.
Hello,
Thanks.
RIG:
Ryzen 5 3600
RX 580 8GB
TUF B450 Plus
The answer is in the Dortania guide. Change AppleALC kext for a VoodooHDA kext.
Doesn't work. With the VoodooHDA.kext I don't have audio.
Did you edited the config.plist with the new kext? The attacched kext works well for me in my msi b450 gaming pro carbon AC.
Nope. Snapshoted config with the new kext and still doesn't work. Does the USB microphone works at least? Therefore I can go USB mic if works.
Again, I have no issues with USB mics or webcam mics with Big Sur.
