Legion5(R7000P 2021A) 5800H+6600M Sonoma EFI
material72
R7-5800H
This EFI is useable on Legion5(R7000P 2021A) 5800H+6600M,Can boot macOS Sonoma
First of All,Thanks for github(https://github.com/kalkmann/Legion-5600H-Hackintosh)
I replace some file about cpu for conveniect other people
everything is ok , but cpu model is incorrect.
I try to fix it but I can't fix it
Reactions: wandayu
@material72
Add RestrictEvents.kext to your /EFI/OC/Kexts folder, with the accompanying entry in your config.plist.
Add these three RestrictEvents NVRAM entries to your config.plist.
revpatch =auto,svbmm
revcpu = 1
revcpuname = AMD Ryzen 7 5800H
link below to download latest kext and readme containing information about the NVRAM > Add entries.
@material72
revcpu = 1
The USBMap.kext is generated in MacOS. Is there anyway to generate my own USBMap.kext in windows?
You can’t use USBMap in Windows, as it is a Mac specific script. You can ‘Edit’ a USBMap.kext/Contents/info.plist in Windows, but you can’t create one.
You have to use USBToolBox Tool and generate a UTBMap.kext in Windows. If you want to configure your system USB ports in Windows.
