lagging macos help pls
wheazzy
lagging macos high sierra on installation . i can`t install it
USB ports aren’t working, as XhciPortLimit Quirk is disabled in the config.plist I provided.
wheazzy
can u help me bro ?
With what?
I posted an alternative EFI folder in another post, that contains the change to the USB port limit quirk.
wheazzy
With what?
thanks i will try it now
wheazzy
it didn't work, it lagging
Is this a USB mouse that is lagging and jerky?
If yes, have you tried it in a different USB port?
wheazzy
Yes , I tried it on other usb ports
wheazzy
maybe Is the lagging from the video card?
Are you connected to the Nvidia card with the iGPU disabled in the bios? If so make sure you've set nv_disable=1 for the install.
wheazzy
I installed it thank u
