Krisp AI 1.30.10 AMD fix, update 1.31.22 and 1.32.16
tomnic
Just replace the main executable in /Applications/krisp.app/Contents/MacOS/krisp with the patched one. Forced the program to detect our AMD cpu as a Genuine Intel, no other tricks involved.
Then codesign again the executable:
sudo codesign --force --deep --sign - /Applications/krisp.app/Contents/MacOS/krisp
  • krisp.zip
x86
Amazing work, do you mind me asking, what exactly did you patch out?
Noxis
Thanks, this worked! I assume that updating to another version later on would override this patch. Can you share how the patch is accomplished?
tomnic
In the meantime 1.31.22 patched krisp executable is here
  • krisp.zip
Reactions: x86
x86
They must've changed something as now with the patched binary on 1.31.22, I go into a login loop. It repeatedly asks for a login.
tomnic
As a workaround you can use the old executable: it works perfectly and the version number remains the latest, 1.31.22
Reactions: x86
tomnic
Use these patched binaries...
/Applications/krisp.app/Contents/Frameworks/libtbb.dylib
/Applications/krisp.app/Contents/Frameworks/libtbbmalloc.dylib
Then issue these commands:
sudo codesign --force --deep --sign - /Applications/krisp.app/Contents/Frameworks/libtbb.dylib
sudo codesign --force --deep --sign - /Applications/krisp.app/Contents/Frameworks/libtbbmalloc.dylib
  • libtbbmalloc.dylib.zip
  • libtbb.dylib.zip
  • krisp.zip
charchar
any chance we could get this for the latest krisp version?
tried patching with amdfriend, but couldn't even get the app to open
tomnic
Screen Shot 2022-06-14 at 22.40.03.pngThe problem with the latest Krisp versions is that no proper entitlements are copied after forcefully recodesigning the app.
This is the way to run it anyway:
sudo amdfriend --in-place --directories /Applications/krisp.app
...so the app will be patched but codesign not replaced (if you replace it with the --sign option in AMDFriend the app won't make you logging in because of special entitlements to access the keychain going lost).
At this stage if you directly run the app you'll get the classic invalid codesign error. Let's go on...
Now open terminal and write:
lldb /Applications/krisp.app
After the app gets preloaded issue this command:
run
Give your admin password when asked and everything will work fine.
Probably you'll need at least Xcode command tools installed.
charchar
Thanks, I'm just seeing your reply.
The first command ran without issues. However when executing:
I get the following response:
(lldb) target create "/Applications/krisp.app"
error: more than one platform supports this executable (host, remote-macosx), specify an architecture to disambiguate
Not sure, how to proceed after this.
UPDATE:
Tried setting --arch flag.
lldb /Applications/krisp.app --arch x86_64
And looked like it worked, got this response:
(lldb) target create --arch=x86_64 "/Applications/krisp.app"
Current executable set to '/Applications/krisp.app' (x86_64).
(lldb)
After that, executed:
run
And received this error:
error: process exited with status -1 (attach failed (Not allowed to attach to process.  Look in the console messages (Console.app), near the debugserver entries, when the attach failed.  The subsystem that denied the attach permission will likely have logged an informative message about why it was denied.))
(lldb)
