Greetings!
I need your advice: I've just installed macOS recently and found that I've messed with Network adapter Kext (used Realtek instead of Intel)
I've tried to update kext on my installation stick (which I still use as my boot device), update config.plst, but nothing has changed: MacOS still not detecting my ethernet adapter
Also, I've noticed that previously, when I started macOS for the first time, I saw long kernel part of loading, but now it is skipped.
My question is: how can I fix my ethernet adapter after installation? Should I change some system files or I did everything right, but just picket the wrong kext which is not working for me?
Thank you in advance!
