Solved Installing Big Sur on Ryzen
Lsx285
Hey everyone,
I'm trying to install Big Sur 11.3 on my SFF PC.
However, I'm stuck on this screen when trying to boot the recovery thingy.
Can someone take a look at my EFI folder?
Specs
Ryzen 5600x
RX 6800 Reference
Gigabyte B550i Aorus Pro AX (Version F13i)
Crucial P2 1TB SSD
EDIT:// for some reason catalina works.. wtf?
It won't fully work. Your GPU required Big Sur 11.4 which is only in the first stages of the beta. You'll either need to use the beta to make an install USB or wait for it to release.
Lsx285
Yea, ik. Luckily I'm able to boot into Catalina (without gpu acceleration etc. obviously) and I'm making an full/offline installer for 11.4 Beta 1 rn.
So I have managed to boot into the very last stages of macOS 11.3 on my 5900X & 6800XT on my B500 Vision D. The problem is that I have gotten to the very last point, and gioScreenLockState appears. Have tried almost everything including adding the above patches and agdpmod=ignore (from Dortania guide for the error) and I have no way of getting past it. I also get a AGDCC: Unauthorized client 'PerfPowerService' error on some test boots. It's a big issue that needs to be looked at.
6800XT requires 11.4 beta. 11.3 didn't include support for the GPU.
slehc84
also you will need agdpmod=pikera .
