install issues, ryzen 7 3700x, gigabyte x570 mobo and radeon 5700xt
h3llb3nt
31
hey all, first hackintosh...
got all my parts together finally and am having trouble getting install working.
followed opencore guide. ran into first error. am failing in the ACPI section i think... tried to decipher based on opencore troubleshooting docs but I am still a bit lost. see screenshot for where i am failing currently.
hardware: https://pcpartpicker.com/user/h311b3nt/saved/#view=7BzH23
gigabyte x570 AORUS elite, updated firmware to v30
ryzen 3700x
gigabyte radeon 5700xt gpu,
samsung nvme 970
fenvi 1750 wifi/bluetooth card
sanity check output -> https://opencore.slowgeek.com/?file=amd061ggbjoA&rs=amd061
also attached is a screenshot of my EFI folder structure and my config.plist.
    config.plist
bueller? anyone? any suggestions?
was advised to pull the SSDT-CPUR out no matter what i read. error is now: 1601938057030.png
Do you have "CSM Mode=Disabled" in your BIOS settings?
yes i do, after work i am going to document all the bios screens and add them here.
going back thru opencore guide (0.6.2) found this:
would be great if "newer" was more specificic. i am using F11 bios on my X570 from gigabyte which is from 2019...
progress!!
I checked my config.plist and yes, there is SetupVirtualMap=False. I have OpenCore 0.6.0 and Gigabyte X570 with the latest BIOS F30.
i got macOS installed.. now to tweak and tune. thanks everyone for the assists at this stage.
