I Can't Access ATTO SAS Raid Disks! Help !
Nota81
Istanbul
AMD Ryzen 3900XT 12 Core
Hello, I have been using Hackintosh with Intel processors for years. In 2011, I bought a STARDOM SOHORAID SR8 raid storage system with the ATTO Express SAS R380 card, and I have been using it actively in all hackintosh systems I have installed. Although the driver support of the ATTO card ended with El-Capitan, I was somehow able to install the drivers even on the Ventura version with the .kext and installation files I had backed up beforehand. A few days ago, I installed an AMD system, I use the version of Monterey I installed for intel with Opencore by making the necessary adjustments, but I cannot reach my ATTO system. 3 days ago, the SAS system, which was working with an Intel i5 8600K processor and MSI z370 motherboard in the same system, became inaccessible with my transition to AMD. I have searched in many places but could not come to a conclusion. The system that works fine in Intel may not be working when the system is switched to AMD. The RAID Card appears to be recognized by the system, but the disk does not come to the desktop. I have removed the old kext files, reinstalled but the situation is the same. Is there anyone who can help me with this issue, maybe there is a command or setting that needs to be turned on via Opencore for RAID systems? Waiting for your replies, thank you.
Edit: There is a program called ATTO Configuration Tool that shows the status of the disks, when I open that program, there is a text "The controller driver must be loaded to access the firmware" on the screen.
Thanks to everyone who will help. Sorry for the Google Translate translation.
My System Properties:
Ryzen 9 3900XT
MSI X470 Gaming Pro Max
32Gb DDR4 3200Mhz Ram
Sapphire Nitro+ 5700XT 8GB
1Tb Corsair NVMe Gen3 M.2 SSD
