HP ProDesk 405 G8 SFF rtl8111 does not work
hirayasu0423
5
Ryzen 5 PRO 5650G
CPU: AMD Ryzen™ 5 PRO 5650GE
GPU: Integrated IGPU - (Likely RX Vega 10 or 7)
RAM: 8GB @ 3200MHz
Motherboard: OEM AMD® PRO 565 Chipset
Audio Codec: Realtek ALC3867 Audio Codec
Ethernet Card: Realtek RTL8111FPH-CG Gigabit Network Connection
NVME: Samsung OEM Pre-installed
I have successfully installed and booted macOS, but I am having trouble with the RTL8111 not being recognized. The Ethernet status in System Preferences fluctuates between "Not Connected" and "Cable Unplugged", and I cannot connect to the internet.
I have tested several older RealtekRTL8111 kexts, but none have successfully connected so far.
I have attached my EFI folder. Could anyone please help me?
The EFI was created following the OpenCore Install Guide.I have manually set a static IP address in case DHCP IP address acquisition fails.I experienced the same connection issues with older macOS versions like Big Sur.
First issue:
  1. You have SSDT-EC-USBX-Desktop.aml plus separate SSDT-EC.aml & SSDT-USBX.aml tables in your ACPI folder and config.plist. This should never be the case.
    1. Remove the Generic SSDT-EC-USBX-Desktop.aml table if you created the other two with Corpnewt's SSDTTime and your system DSDT.aml table.
  2. You don't need the ACPI > Patch for EC0 _STA to XSTA Rename in your config.plist, I have never required this with any of my AMD systems.
  3. Doesn't look like the SSDT-PLUG-ALT.aml table was created for your system. Too many CPU threads in the table for your 6-core/12-thread CPU.
Second issue:
  1. You have a HP system, but have failed to enable the two HP specific entries in the config.plist. Both of these should be enabled in the config.plist.
    1. Kernel > Quirks > LapicKernelPanic
    2. UEFI > Quirks > UnblockFs Connect
Third issue:
  1. You should never use any DeviceProperties when using NootedRed.kext. You have two in your config.
    1. The Audio should be set with a boot argument alcid=12, if you want to use layout-id=12.
    2. Not sure wha you are trying to fix with the second entry in the Device Properties. I doubt this will fix/disable any CFG Lock issues.
  2. Using these DeviceProperties may be causing the Ethernet port to malfunction.
Fourth issue:
  1. You have Kernel > Quirks > DiableIoMapper set as True. This is wrong. As this quirk is irrelevant to AMD systems as they don't have DMAR or VT-D support.
  2. You are lacking a custom USB configuration, i.e. USBMap or UTBMap.kext, so you should enable Kernel > Quirks > XhciPortLimit option.
  3. your should change Misc > Boot > PickerMode from 'Builtin' to 'External', to make use of the OC GUI boot screen.
  4. You should change Misc > Security > SecureBootModel from 'Default' to 'Disabled'. This will cause you less issues when updating the system.
  5. You have failed to add an entry to support your keyboard language- prev-lang:kbd should be set for your keyboard language, leaving this empty has been know to cause unexpected issues when booting macOS.
  6. You have a different audio layout-id (alcid=1) in your boot arguments, which would supersede the DeviceProperties entry layout-id=12. Which is correct?
  7. You should add 'auto' to the revpatch NVRAM entries, to fix any Memory or PCIe issues that commonly occur.
Try the revised EFI on a spare USB pen drive, see if this makes any difference.
外部の
Dear Edhawk,
I am very sorry for the delay.
Thank you for your detailed explanation.
However, the issue persists despite trying the suggested solutions, using EFI, and consulting various websites.
In hackintool, the Internet and Audio sections under Peripherals are not displayed.
I'm not sure if it will be helpful, but I have attached images of hackinntool and pcidevices.txt!
I apologize for taking up your valuable time again, but could you please check the attached files?
Thank you for your assistance.
  • pcidevices.txt
    pcidevices.txt
Post a copy of your current OpenCore EFI so we can see what you are using. Just make sure you redact/delete your serial number from the config.plist before posting a copy here.
Check your bios settings for these devices/components. Make sure you haven't disabled them by mistake.
Absolutely! Here's the translation of the provided text into English:
Of course! Thank you for your response.
I have confirmed that both the Internet and Audio are enabled in the BIOS settings.
I have attached my EFI folder for your further review.
I can’t see any issue in the EFI that would prevent the Ethernet, Audio or any other components working in macOS. All the expected kexts and config.plist entries are present and enabled.
Check in System Settings > Network preferences pane to see if the Realtek Ethernet port has been added to the system.
The main reason for the Audio codec not showing up in the system, is that you are using the wrong layout-id for the audio device. Have you tried any other id’s?
What do the Hackintool > Sound tab and System Information > Audio tabs show for your system?
Sorry for being so late.
I checked and found the layout ID of the correct audio device, and when I reflected it, the audio codec appeared on the system.
The Realtek Ethernet port is loading the driver, but I can't add a network from the settings screen.
Also, when using the latest RTL8111 driver, nothing is displayed on the Etensions screen of the hackinttol screen.
Even if you use npci=0x2000 and e1000=0 in bot-args, the network is currently unusable.
Are there any other possible causes besides the above?
We apologize for the inconvenience. . . .
    EFI.zip
Try this Revised EFI.
You need to remember that adding DeviceProperties to your config.plist (for your Audio device in your case) isn't supported when using NootedRed.kext.
I have added alcid=12 boot argument to replace the DeviceProperties.
Replaced the Realtek Ethernet kext with the latest version 2.4.2.
Removed a few SSDTs that your system doesn't need.
Made a few other changes that are more in keeping with the OpenCore guide.
thank you!
For now, it starts up, but I can't use the internet.
When using the above EFI, all Etensions screens were hidden and the Internet settings screen was displayed.
However, even though it has been connected for a long time, it is not connected.
The same is true for the latest version of the Ethernet kext, version 2.5.
Also, with the older version 2.2.2, you can see that the driver is loaded on the Etensions screen, but the mac address will no longer be displayed on the Internet settings screen.
I know you are busy, but I would be grateful if you could help me. . .
The Ethernet controller not working may be caused by something else, not the kext. I helped someone on a different site and their Ethernet problem was caused by a bios setting, which was unrelated to the network connection issue.
