HP EliteDesk 705 G4 Mini PC Hackintosh Help
aztm22
Ryzen 2400g
Model: HP EliteDesk 705 G4 Mini PC
CPU: Ryzen 2400GE CPU
iGPU: AMD VEGA 11
RAM: 32GB DDR4 2400MHz
SSD: M.2 NVMe Solid State Drive
Trying to get macOS Ventura running, i have done hackintosh before on intel systems and even have a HP EliteDesk 800 G3 with Intel i5 running macOS Ventura, any help on what i need to complete this would be great
Which NVME M.2 drive is present in the HP system, if it is a Samsung drive (PM991 or similar) you may need to swap it out for a more compatible drive form Western Digital or another manufacturer.
Let's assume the following:
  1. You are fully aware of the tasks required for creating an OpenCore EFI, as you have already Hack'd a similar Intel HP system.
  2. You are able to confirm the different components in your HP, using Windows Device Manager, i.e. Motherboard chipset, Audio codec, Ethernet controller, USB Controllers etc.
  3. You can download and extract the OpenCore EFI folder and Sample.plist
  4. You know how to remove any unnecessary Driver and Tools from these two sub-folders in the EFI.
  5. You know how to add the HFSPlus.efi driver to the Drivers folder.
  6. You know how to copy the populated Resources sub-folder from the OcBinaryData-Master folder and place it in the OC folder.
  7. You know how to download and add the kexts required for your AMD APU system to work (those listed below can be found on the OC Gathering Files section of the guide).
  8. You know about following the Ryzen OC guide.
  9. You know how to generate and test a compatible SMBIOS (iMac20,1) using Corpnewt's GenSMBIOS script.
  10. You are aware of the need for a Plist Editor, such as Corpnewt's ProperTree.
You have some reading and file gathering to do.
Your HP system uses the Conexant CX20632 audio codec.
There are layout ID's that work with this audio codec - 20, 21 & 23.
Two of the three IDs were created for similar HP systems, with layout-id=23 being the closest match for your setup.
Screenshot 2023-12-24 at 19.30.46.png layout-ids for Conexant CX20632 present in AppleALC.kext.
Hi I have some like PC
HP elitebook 745 g5
CPU: Ryzen 2500U Pro CPU
iGPU: AMD VEGA 8
RAM: 24GB DDR4 2400MHz
SSD: M.2 NVMe Solid State Drive (with the NVM fix)
I'm getting this
log iokit daemon kernel managerd stall [#] 240s multiple entries holding the registry bussy iokit termination queue depth 0 igpu (a,2000001), pci1002,15de (1e,20000001)
I have managed through the first install and the second one apple logo, then it restarted, and then again, but now say that, thanks in advance
edit:my noob error, it managed to get through after some time it have passed that (I have restarted before because I was thinking it was an fatal error), now it keeps restarting on region selection, I have put the CpuTscSync and the TSCAdjustReset.kext (and put the 7 on it) and it keeps restarting
HP elitebook 745 g5
iGPU: AMD VEGA 8
I'm getting this
Give this a shot, add your platform info. MacPro 7,1
