How to create a macOS installation support WITHOUT using Terminal and Apple servers through a user friendly GUI
Mac Arthur
Along the years I can no longer count how many OSX/macOS installs I have performed on real Macs and Hackintoshes as well.
While helping other users on other forums I discovered that the main reason for an installation to fail was a USB bootable key or other SSD support) not properly created.
I propose hereafter a simple way to automatically create a valid installer (EFI obviously needs to be added to boot in case you are booting a Hack) :)
MDS free software (for "Mac Deploy Stick"), powered by Mist
This software allows a multitude of things and was created for the deployment of software distributions on a fleet of Macs.
Suffice to say that its possibilities go well beyond the simple installation of a version of OSX/macOS on a single computer, but "who can + can -", and therefore why deny it if it can be of any help?
It allows you to download the distributions available on Apple's servers, (High Sierra, Mojave, Catalina, Big Sur, Monterey, Ventura and Sonoma (public and beta) at the time of editing this post, jjust like with GibMacOS.
You can as well download IPSW versions for Intel T1-T2 chipsets and Apple Silicon SoCs. Obviously the build you are looking for must be on the Apple servers, no magic trick here... :)
In my opinion, MDS has the advantage for the non expert (of which I am a part), once installed, of fully automating the download process, even going as far as creating the bootable key, without having to go through the Terminal and the famous "creatinstallmedia" command.
This ease of use makes it worth testing!
The software is downloaded from the following address:
Be careful NOT to download version 5.x as it is now a paid version.
Once the software has been downloaded, installed and launched from the Application directory, it is not necessary for our purpose to create a SSL certificate.
Even if it may seem complicated, we will actually only be interested in the DownloadmacOS tab
We can directly display different classic Catalogs, namely Public and Developer for what interests us.
You just need to choose what you want (one or several files that will queue ...) and start the download.
When prompted, choose the desired directory to save the .DMG file to download and ... wait.
You can follow-up the progress of the download by pressing the Cmd-L keys.
Once the download is complete you can create the bootable key.
For that we open first the downloaded .DMG, we then open the highlighted application folder and we have the installer we want to key. Just select it with the "Select macOS Installer" button. (The selection does not allow to open the DMG if we have not done it before )
Then select the name of the desired key with the "Target Volume" button and launch the creation of the bootable installation key after having clicked on the padlock to unlock and make the "create" button available.
The software warns that theUSB key will be completely erased. We click and let's go! You can consult the Log file which displays in real time what is happening.
The notable advantage over gibMacOS, is that you can store your downloaded files wherever you want (and therefore the installer does not necessarily have to be in the "Application" folder), and that you can give your key whatever name you want ... all without entering a single command line in the Terminal
Make good use of it!
tuort
How long should it approximately take to download the installer, let's say Sonoma 14.5
All depends on the speed of your Internet connection and any limitations your Internet provider imposes on your connection.
The faster the connection the quicker the download.
tuort
@Edhawk
Thanks I fully understand, but everything being equal I found that this new method seems to take much much longer. I cannot figure out why, I would prefer using this new method, I will have to try it again and see if I get the same results .
There is nothing wrong with using Corpnewt's gibMacOS script to download the macOS release you want from the Apple Servers. It works perfectly well in Windows and macOS.
Select the Green coloured button named 'Code' and select 'Download Zip'.
Then select the gibMacOS.bat (Windows) or gibMacOS.command (macOS) option in line with the OS you are currently running.
Screenshot 2024-07-02 at 22.46.02.png Screenshot showing macOS versions available from the Public Release catalog
A full installer is between 12GB & 14GB in size, depending on the OS you select for download. Assuming you want to install a recent version of macOS, i.e. Big Sur or newer. Older versions of macOS are much smaller downloads.
tuort
@ Edhawk
Thanks , I am pretty sure I've used this before with no issues
