[Help] stucked at kernal patches (bulldozer)
thewayur
India
Amd FX 6300
see my signature for hardware,
2 errors i can not figure out:
  • 16 patches found - Did you apply the kernel patches correctly? Please review the Kernel Docs
  • You should have exactly 12 settings in the UEFI/Output section
pls see attachments for config.plist and patch.plist
about patches.plist
it came from: AMD_Vanilla-master / patches.plist.
after that i edited algrey - Force cpuid_cores_per_package for 6core
guide me how to correct them plz
At a quick glance your config seems ok. Except AppleALC won't work on FX so you'll need VoodooHDA and also XLNCUSBFIX.
Reactions: thewayur
REQUEST: if someone can please send me working EFI folder, and tell me which parameteres i need to customize it will be really hepfull.
so i tried again as fresh, stucked on blinking cursor right after usb boot.
problem is my asrock mobo doesnt have anything like
fastboot, secure boot, csm, 4g decoding, ehcl/xhcl...
below i am attaching (pic_2.jpg) serial/parrallel port screenshot but i am not sure if they r what i want
also please check my efi folder.
and here is my folder structure
e:\com.apple.recovery.boot
e:\EFI
e:\System Volume Information\WPSettings.dat
e:\System Volume Information\IndexerVolumeGuid
e:\com.apple.recovery.boot\BaseSystem.chunklist
e:\com.apple.recovery.boot\BaseSystem.dmg
e:\EFI\BOOT
e:\EFI\OC
e:\EFI\BOOT\BOOTx64.efi
e:\EFI\BOOT\.contentFlavour
e:\EFI\OC\.contentFlavour
e:\EFI\OC\OpenCore.efi
e:\EFI\OC\ACPI
e:\EFI\OC\Tools
e:\EFI\OC\Drivers
e:\EFI\OC\Kexts
e:\EFI\OC\Resources
e:\EFI\OC\config.plist
e:\EFI\OC\ACPI\SSDT-EC.aml
e:\EFI\OC\ACPI\SSDT-USBX.aml
e:\EFI\OC\Tools\OpenShell.efi
e:\EFI\OC\Drivers\OpenRuntime.efi
e:\EFI\OC\Drivers\HfsPlus.efi
e:\EFI\OC\Kexts\VirtualSMC.kext
e:\EFI\OC\Kexts\Lilu.kext
e:\EFI\OC\Kexts\WhateverGreen.kext
e:\EFI\OC\Kexts\VoodooHDA.kext
e:\EFI\OC\Kexts\XLNCUSBFix.kext
e:\EFI\OC\Kexts\RealtekRTL8111.kext
e:\EFI\OC\Kexts\AppleMCEReporterDisabler.kext
e:\EFI\OC\Kexts\VirtualSMC.kext\Contents
e:\EFI\OC\Kexts\VirtualSMC.kext\Contents\Info.plist
e:\EFI\OC\Kexts\VirtualSMC.kext\Contents\MacOS
e:\EFI\OC\Kexts\VirtualSMC.kext\Contents\MacOS\VirtualSMC
e:\EFI\OC\Kexts\Lilu.kext\Contents
e:\EFI\OC\Kexts\Lilu.kext\Contents\Info.plist
e:\EFI\OC\Kexts\Lilu.kext\Contents\MacOS
e:\EFI\OC\Kexts\Lilu.kext\Contents\MacOS\Lilu
e:\EFI\OC\Kexts\WhateverGreen.kext\Contents
e:\EFI\OC\Kexts\WhateverGreen.kext\Contents\Info.plist
e:\EFI\OC\Kexts\WhateverGreen.kext\Contents\MacOS
e:\EFI\OC\Kexts\WhateverGreen.kext\Contents\MacOS\WhateverGreen
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents\Info.plist
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents\_CodeSignature
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents\MacOS
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents\_CodeSignature\CodeResources
e:\EFI\OC\Kexts\VoodooHDA.kext\Contents\MacOS\VoodooHDA
e:\EFI\OC\Kexts\XLNCUSBFix.kext\.DS_Store
e:\EFI\OC\Kexts\XLNCUSBFix.kext\Contents
e:\EFI\OC\Kexts\XLNCUSBFix.kext\Contents\Info.plist
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\Info.plist
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\MacOS
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\Resources
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\MacOS\RealtekRTL8111
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\Resources\en.lproj
e:\EFI\OC\Kexts\RealtekRTL8111.kext\Contents\Resources\en.lproj\InfoPlist.strings
e:\EFI\OC\Kexts\AppleMCEReporterDisabler.kext\Contents
e:\EFI\OC\Kexts\AppleMCEReporterDisabler.kext\Contents\Info.plist
e:\EFI\OC\Resources\Label
e:\EFI\OC\Resources\Image
e:\EFI\OC\Resources\Audio
e:\EFI\OC\Resources\Font
