[Solved] Help pls!!!
microyulive
Hi guys!
As you can see from the pic, I tried to install macOS 12.5. And I am stuck on the process of booting(OC 0.8.3)...
I think there is something wrong with the EFI...
The processor is amd ryzen 3800x, graphic card is amd radeon vii and motherboard is rog stirx x470-f (with i211 net and I use the appleigb kext).
I made the efi file following the guide on https://dortania.github.io/ and also did usb map with usbtoolbox on Windows.
I don't know what's wrong with it...
Could you pls help me with it?
Thank you!
  • opencore-2022-08-14-070413.txt
Warlock88
i have like this installer in last 12 minutes black screen "kill all process" and afteri can start again from 0....
Amd ryzen 5 2600x
asus b450 -f gaming
Amd ryzen 5 2600x
asus b450 -f gaming
Check your core cpu settings under Kernel > Patches and see if the core count matches the same number as your 2600X (which should be 6). The guide for the settings can be found here > https://github.com/AMD-OSX/AMD_Vanilla
