Help please
pampas
Hi!!
I need to do a screen record with audio, is it possible? Can you tell me how?
Thanks
Go to the QuickTime Player application; choose File/New Screen Recording. Choose if you want to record all your screen, or a portion of your screen, then click on the Record button. Click on the Options menu. Choose the appropriate audio source.
pampas
I know the Shaneee. The problem is I have no audio on the recorded part. I can listen the sound during the record but not after. Do I have to use an external mic??
Is is external sound you're recording or the audio from the PC?
pampas
ScreenFlow should suit your needs. It is however a paid application but offers a free trial first.
pampas
OK. I´ll take a look. Thanks once more for your help
