Help needed with Ryzen 9 7950x and MSI x670 MAG ACE
ninjaskija
36
ryzen 9 7950x
Hey guys,
This is my first time posting here. It's been a long time since I've used a Hackintosh (the last was Sierra), and I was thinking of giving it another try.
I have some issues posting (see the attached screenshot).
I've also attached the EFI folder that I have been using along with the OpenCore logs.
Configuration:
CPU: Ryzen 9 7950x
MB: MSI x670 MAG ACE
RAM: 96GB Crucial 5600 DDR5
NVME: Samsung 990 Pro 2TB
Bios settings:
Secure Boot: disabled
CSM: disabled
RBAR: enabled
Any input help will be greatly appreciated.
Thanks!
Hi
I forgot to mention that I have used this as a starting point
You dont use a proper MMIO whitelist configured
ypu have to use a debug version of opencore and enable target to 67 and post then a complete opencore log
Reactions: leesurone
Hi @fabiosun, thanks for chipping in! Here it is!
If you see MMIO are uflagged so in your debug we dont have any mmio area exposed
In booter/quirk section select DevirtualizeMMIO quirk and post again your log
Sorry if i have explained it in a wrong way before
also which GPU are you using?
IGPU (i think you know) it is not supported, you can boot the same but no acceleration , if you post your debug with mmio it is possible to prepare a "booting"EFI meanwhile you will receive 6950xt
Yes, I know. I will probably need some help in setting that up as well ;). As fas as I know the 6xxx series is officially supported up until 6900 XT
I have a 6950xt and it works with a simple spoof
Here it is. Now it seemed to go a little bit further because it looks like this:
Your system has same MMIO area i have in the one useful to boot
if you like try this EFI:
It could be possible to have to insert also some ACPI patches like in ASUS motherboard
You have also a 10 Gbit ethernet and it needs some patches (i think) to add
but for now let see if you do a step forward
I added also sysreport flag if you need some acpi patches post dsdt .aml you could find in sysreport folder of your EFI
@CorpNewt from AMD OSX discord has found a way to solve this (if youor motherboard needs it)
It's not working still.
Attached the logs.
Check my previous message
we need acpi folder (only dsdt.aml file you can find in your EFI partition (folder sysreport)
If you see in photo you have some ACPI errors
Sorry about missing that, coffee didn't have any effect apparently ;).
Here it is.
posted here to CorpNewt
he knows how to patch your dsdt
Your actual EFI should be good to boot if you have done a full installer (all osx from big sur to Sequoia) when he will do acpi patches for you
Thanks! Unfortunately, I don't have access to that discord channel...
LE: managed to join but I the link does not work for me
He did for you and i configured them in your config.plist
Let see if you go further :)
It would useful only by now to see if you have ACPI errors like before
Sysreport and Opencore log not useful for this
