Hi guys, I hope you’re fine!
I embraced the project to Hackintosh the HP ZBook Fury 15.6” G8 Laptop.
This laptop features the AMD Radeon Pro W6600M GPU with 8GB of VRAM.
This would be an absolute beast with MacOS, except I couldn’t get graphics acceleration with it yet.
Boot (ok), MacOS install (ok), everything working like a charm except for GPU acceleration.
The AMD Radeon Pro W6600 is natively supported by Apple, this “Mobile” version is supposedly the same, except for lower TDP. That’s why I’m feeling there must be something to make this work.
I’m attaching DSDT, Ioreg and SysReport here.
Any suggestions are welcome at this point!
Note: This laptop has BIOS deactivation of its iGPU. In the AIDA64 system report you can see no traces of iGPU whatsoever. Everything (screen, HDMI) is processed exclusively through the W6600M so I think an iGPU is probably not the culprit here.
Note 2: An attempt to activate this dGPU was made in a recent livestream in a prominent Brazilian Hackintosh channel,
Graphics Processor Properties:
Video Adapter - AMD Radeon Pro W6600M (Navi 23)
Video Adapter AMD Radeon Pro W6600M (Navi 23)
BIOS Version 020.003.000.030
BIOS Date 6/9/2021
GPU Code Name Navi 23
Part Number BR77941.001
PCI Device 1002-73E1 / 103C-8872 (Rev 00)
Transistors 11060 million
Process Technology 7 nm
Die Size 237 mm2
Bus Type PCI Express 4.0 x16 @ 4.0 x16
Memory Size 8 GB
GPU Clock 12 MHz
RAMDAC Clock 400 MHz
Pixel Pipelines 64
Texture Mapping Units 112
Unified Shaders 1792 (v6.5)
DirectX Hardware Support DirectX v12.0
WDDM Version WDDM 3.1
BIOS Date 6/9/2021
Die Size 237 mm2
Memory Size 8 GB
GPU Clock 12 MHz
Pixel Pipelines 64
