Hello my macbook had a error that requires another mac but i dont feel like going to a apple store and i dont have any other macs, i been trying to hackintosh my HP laptop for the whole weekend and i havent made it anywhere past the efi, if anyone can help please help, my specs are HP Laptop 15z-fc000 ryzen 7530u 32gb ram, if you need more info please ask. also more info this is not the first time i attempted to install mac os, last times the efi did not work, and im not a hack wiz which makes it harder for me to understand.
*** First of all, don't make any changes to the vmware .vmx file. It is recommended that you create a new virtual machine from scratch so that it recreates this file by default and without any changes.
*** Use VMWare Workstation Pro version at the link provided in the tutorial. (If you install it, you will have to make a new Patch as described)
*** Enable AMD-V or INTEL VT (Virtualization Technology) in BIOS. (you should research how to do this on your machine)
1) First you need to download VMWare Workstation Pro:
- VM Workstation Pro 17.6.3: (NOW...
You should hopefully be able to fix your Mac with a macOS VM.
