Help me to Fix My Ethernet
surf3rninja
25
Ryzen 5 3600
Config List:
-CPU: AMD Ryzen 5 3600X 6-core Processor
-Motherboard: Asus ROG Strix B550-F
-GPU: SAPPHIRE NITRO + Radeon RX 480 8GB GDDR5
-RAM: G.SKILL TridentZ RGB Series DDR4-3000 CL15-16-35 1.35V 32GB (4x 8GB)
-CPU-Cooler: AMD Wraith Stealth Socket AM4 4-Pin Connector CPU Cooler with Aluminum Heatsink & 3.93-Inch Fan (Slim)
-Disks:
Windows11: Samsung SSD 840 EVO 1TB.
For macOS: 970 EVO Plus NVMe M.2 1TB
Storage: Samsung SSD 840 PRO 512GB
-Power Supply: Thermaltake Smart 700W 80+ White Certified PSU, Continuous Power with 120mm Ultra Quiet Fan, ATX 12V V2.3/EPS 12V Active PFC Power Supply PS-SPD-0700NPCWUS-W
-Case: NZXT H510 - CA-H510B-W1 - Compact ATX Mid-Tower PC Gaming Case - Front I/O USB Type-C Port - Tempered Glass Side Panel - Cable Management System - Water-Cooling Ready - White/Black
-System: Win11
-Bios Version: 2423 x64
I have created my EFI. Everything works fine except Ethernet. Ethernet shows connected but no internet connection. Can anyone tell me how do I fix this? I am attaching my EFI can anyone check this?
Hey man. I'm afraid, you have an Intel I225-V ethernet. Since Monterey it's kinda hit and miss for everybody. I'd suggest you get a USB ethernet adaptor till somebody updates the intel nic kexts.
Config List:
-Disks:
-System: Win11
Try adding e1000=0 to boot-args.
I had the same problem, the intel ethernet on my board don't work fine. The best option is to use a USB ethernet adapter. You don't need kexts and it works plug and play.
Reactions: clover84
Pretty much any USB3 to Ethernet adapter will work in macOS, as Apple provide native drivers for these adapters. Mainly due to a number of MacBook's not being provided with ethernet ports.
Have a look at the Amazon UK page linked below, for prime examples of some Mac compatible adapters.
  • Love
Reactions: Galve2000
