[HELP] Completely Nvidia dGPU disabling
tiagoadriao
13
Lisboa, Portugal
Hello all!
I'm trying to completely disable my GTX 1060 and use only my second GPU GT 740 for Hackintosh.
I've follow both options from Dortania's Guide https://dortania.github.io/OpenCore-Install-Guide/extras/spoof.html#windows-gpu-selection
But the Issue here is that I can spoof it alright, but I still have issues with audio controller of GPU, which gives wake issues for my system.
I've tried disable it via DeviceProperties and SSDT and both outputs the same result, it shows "Display" and "NVIDIA GeForce GT 740 on System Report and IORegistryExplorer.
If I physically remove the GTX 1060, my system as no issues to sleep/wake.
Is there anyway to completely disable GPU and all its components?
Thank you.
