Hi!
I have ran into an issue with webdriver, if I have every monitor connected to the card when booting i just get a black screen on one of them, however if I only leave one connected it boots fine and I can even just plug and play the other ones for it to work perfectly.
Has anyone run into this issue before? I tried booting without whateverkext and using different webdriver versions but none of them fixed the problem.
My system:
3900x
TUF Gaming x570 Plus
32 GB 2400 mhz ram
Gainward GTX 1080
The gpu itself worked perfectly on previous install (which was actually x99 based so it had a ton of random kernel patches etc to even function with that board).
Thanks,
sen
My system:
3900x
32 GB 2400 mhz ram
Gainward GTX 1080
Thanks,
sen
