Configuration:
Remarks:
Remember to update the serial numbers if you download the EFI folder!
- CPU: AMD Ryzen 6 3600
- MB: Gigabyte B450 Aorus M (Micro-ATX)
- GPU: Asrock Radeon RX 5700 XT Challenger D 8G OC
- NVMe: XPG 512G, running Windows
- SSD: Crucial MX500, 500GB, SATA, running MacOS
- Audio: Sennheiser GSX 1000 (external USB DAC/amplifier)
- LAN: onboard
- Display: 4K LG 27UL650-W, connected through display port
- HyperX Alloy FPS Pro, LED
- Memory: 2x Crucial Ballistix Sport Lt, 8GB 3000MHz (CAS 15)
- Logitech MX Master 2S connected though its proprietary dongle.
- Version F50 (not the latest, which is F51f
Remarks:
- I have installed the 10.15.5 and then upgraded to 10.15.6. After a few reboots, everything was fine.
- The Logitech mouse software was a little annoying to install and configure.
- I am working daily for about one month. Not a single freeze after I had disabled the sleep.
- The monitor reduces its brightness, when I am watching a Youtube video in full screen. Then I get out the full screen and everything goes back to normal.
- A key from my (USB) keyboard fails. I have to unplug and then plug the USB cable and it works again. Maybe it is a keyboard issue.
- The external DAC/Amp is off. I have to disconnect and reconnect it again.
- Some applications, like Safari, freezes for a second or two and then returns to the normal operation. Maybe it could be the slower IO (SATA). I will use CCC to transfer the MacOS to the NVMe and see if it reduces this lagging.
- I believe that the integrated sound don't work, but I am using an external DAC/Amp that works quite well. Better than in Linux.
- Sleep. Turn off the display works.
- Check the GPU performance. The Geekbench score is too low. I will check this: https://www.insanelymac.com/forum/topic/343461-kext-tired-of-low-geekbench-scores-use-radeonboost/
