getting AVX on ESXi Monterey 12.4 VM with Ryzen 5950x
alfie
/usr/sbin/sysctl -n machdep.cpu.features machdep.cpu.leaf7_features
Is anyone running a Ryzen zen3 VMWARE vm that has AVX 1.0 ENABLED as a cpu FEATURE?
(If you run the above command in a macOS TERMINAL it will show you.)
I have added the only CPU lines found on the web for getting a Ryzen Processor to Boot macOS under VMWARE. It works BUT AVX 1.0 is not enabled.
Can anyone check to see if yours is enabled and post relevant vmx lines OR file.
Thank you kindly
ESXi or VMWARE Workstation
Ryzen 5950x
macOS MONTEREY 12.4
