Thank you so much!Some stuff works and some stuff doesnt.
cubase, wavelab are no goes.
Logic works well and so does all of its plugins.
brainworks, Ozone, FabFilter all work fine as plugins but then there’s a lot of plugins that doesn’t work too.
overall your much better off with an Intel build if you use a lot of different daws, audio apps and plugins but if your using logic mostly then your probably be fine.
You’re Welcome buddy,Thank you so much!
I mostly use Wave's plugins and a few instrument plugins from XLN and Arturia.
Do these work fine on a ryzentosh?
