Control GPU Fan (SAPPHIRE NITRO+ Radeon RX 580), Over temp causing Shutdown
walidur234
25
7
AMD Ryzen 7 3700x
I was using OBS with default settings to record my screen. After a while, my GPU overheated and shut down automatically, likely reaching temperatures as high as 90/100ºC. Fortunately, there was no hardware damage as far as I know, except for a minor burn on my finger when I touched the heatsink due to having an open case. After the shutdown, I waited, booted into Windows, and allowed it to fully cool down.
In macOS, the typical GPU temperature ranges between 46-55ºC. I observed that the fan operates at a very low RPM once a certain temperature threshold is surpassed. So, I'm interested in manually controlling the GPU fan.
If there's a tool similar to "AMD Power Gadget" for GPU control, that would be greatly appreciated. Thanks In Advance
System Spec:
MSI b40m Mortar Max
AMD Ryzen 7 3700x
Solution
Thank you, Edhawk.
The fan is operating as intended—I've configured it to spin at 42ºC with a 40% speed. Additionally, would there be any issues if I were to run the fan continuously at this speed? Noise isn't a concern for me.
There would be No issues as far as I am aware.
Reactions: walidur234
