Can't upgrade from Big Sur to Monterey - ASRock X570 ITX TB3 - 3900x - 5700 XT
j_bravo14
Been trying for a couple of days now with no success. It was initially in Catalina, then upgraded to OC 7.5 and then to Big Sur successfully.
It's a no go for me when I try the OTA upgrade or USB drive upgrade. It is stuck at boot on apple logo then restarts
OC: 7.5
System Specs:
MB: Asrock 570 ITX/TB3
CPU: 3900x
VC: Asrock Challenger 5700xt
  • EFI - X570 ITX.zip
bump! any help from our experts here?
Hi j_bravo14,
Okay, I guess you're trying to upgrade to Monterey. Try this. Update your OC to at least v0.7.8/8.0 and add AppleMCEReporterDisabler.kext to your kext.
Disable XHCIPortLimit and enable USBInjectall.kext, and enable ProvideCurrentCPUInfo. If you have SSDT-UIAC and SSDT-EC-USBX.aml I'd enable those too.
You can use OCAuxiliaryTools (OCAT) to do this.
Moozuki
USBInjectall does not work with AMD.
In that case they'll need to create a USB map with UTBToolbox under Windows with the two SSDTs enabled.
