Can't upgrade from Big Sur to Monterey - ASRock X570 ITX TB3 - 3900x - 5700 XT
j_bravo14
Been trying for a couple of days now with no success. It was initially in Catalina, then upgraded to OC 7.5 and then to Big Sur successfully.
It's a no go for me when I try the OTA upgrade or USB drive upgrade. It is stuck at boot on apple logo then restarts
OC: 7.5
System Specs:
MB: Asrock 570 ITX/TB3
CPU: 3900x
VC: Asrock Challenger 5700xt
  • EFI - X570 ITX.zip
OC: 7.5
System Specs:
CPU: 3900x
Have you tried adding AppleMCEReporterDisabler.kext to your build? It should help you get past it. Also would recommend enabling AdviseWindows under PlatformInfo.
Havakak
AppleMCEReporterDisabler.kext is the solution. I've just installed Monterey successfully with the help of that kext.
