Big Sur 11.0 Beta (20A5343j) | B550 Aorus Pro
Fooose
The installation went through without any real problems.
I am really fascinated by the design!
hasrt1206
How did you manage to install Big Sur?
I have tried many tutorials but none seem to work for me.
It's not really difficult anymore with OC 0.6.0.
Fooose
Use my EFI and it works without problems, the only important thing is that you don't need the "AMDRyzenCPUPowerManagement.kext", because there were problems with it, at least for me
Lilu userspace patching is not working with KernelCollection, kexts using it like AMDRyzenCPUPowerManagement.kext currently don't work until it's fixed. Was working with prelinked kernel before though. Older versions of AMDRyzenCPUPowerManagement.kext before 0.6.0 don't use that feature and still work on BigSur.
RyzeCooker
Just a quick note that AMDRyzenCPUPowerManagement has just been updated to 0.6.5 to address specifically the Big Sur problem.
Fooose
New Version of AMDRyzenCPUPowerManagement --> Fixes issues in symbol resolving that cause panic in Big Sur.
