I recently bought a BCM94360CD, wifi and bluetooth work fine in windows. But in mac(10.15/macos12.6.5....) wifi doesn't work (bluetooth works without any kexts).
In system reports and web interfaces:
Can't see this card under System - Misc in hackintool. But you can see it under PCIe.
My machine is Legion 5 pro 2021, this is the spec : https://github.com/JamisonMurphy/Legion-5-Pro-Hackintosh
My EFI:https://github.com/JamisonMurphy/Legion-5-Pro-Hackintosh/tree/dev
Already tried to disable/enable Kernel-Quirks-DisableIoMapper, still not working
system reports (BCM94360CD)
intel ax200 wifi/BT work fine by itlwm. But when BCM94360CD is plugged in, there is no wifi option in this interface
web interfaces (intel ax200)
PCIe
