B450 Tomahawk Max + Ryzen 5 3600 | Big Sur 11.6 | Opencore 0.7.4
nampham85
I just successfully installed Ryzentosh on my PC
My hardware:
  • Motherboard: B450 Tomahawk Max (Bios Release Date 18/01/2022 - 7C02v3C)
  • Ryzen 5 3600
  • NVME WD250G
  • Kingston HyperX 8G Bus 3200 (x 4 stick)
  • Gigabyte Radeon RX Vega 56 8GB
  • Wifi BCM94360CS2
  • Opencore 0.7.4
(I can not enable XMP to get bus 3200 because of getting BlueDeath on Windows. Maybe this bios version still has some issues)
Everything works perfectly
My EFI was attached. Pls use GenSMBios to take your PlatformInfo
  • B450 Tomahawk Max - Opencore 0.7.4.zip
spivix
can you please share the efi? thanks
edit: sharing the config.plist works too
