Hi there, recently i've started working with some LLMs and I need AVX2 CPU feature enabled, but in my hackintosh environment isn't enabled for some reason. Is there any way to enable it? On Windows the AVX2 feature is enabled
To my knowledge, Apple's Rosetta 2 translation layer does not support AVX2 instructions on Intel Macs. So I would assume it will be the same for your AMD hack.
What does Terminal show when you run this command:
sysctl -a | grep cpu.feat
My Ryzen 9 5900X shows the following list of CPU Features/instruction sets.
Only AVX1.0 is shown. Even though Windows will show AVX2 as being present and enabled.
It is one way for Apple to push people to buying an Apple Silicon system. As some Adobe software and probably others as well require AVX2 or the equivalent Arm instruction set for their latest releases to work.
