Android Studio on AMD Hackintosh
wesbaldur
Hi , any way to run android studio? is it possible? I have AMD Hackintosh
Should work as long as you follow the instructions below.
Screenshot 2024-09-05 at 19.52.54.png Minimum Requirements and installation process for Android Studio on Mac.
If you run in to issues, you could try adding AMDFriend.kext to your OC setup and see if that helps.
