AMD Ryzen 7 5700G vs Ryzen 7 5700X
HKPhysicist
52
AMD Ryzen 5 5600H
You don't need to compare them, but if that is what you want, have a look at these comparison pages:
The main differences as I see things are as follows:
The Ryzen 7 5700X supports a higher PCIe standard, 4.0 vs 3.0 for the Ryzen 7 5700G, which may make some difference when using higher-end/faster NVMe drives.
The Ryzen 7 5700X supports double the PCIe bandwidth (39.4GB/s vs 19.7GB/s), double the amount of Memory (128GB vs 64GB) and has double the L3 cache (32MB vs 16MB).
The Ryzen 7 5700X performs approx. 8-12% better in most benchmark tests. Only really important if you are a benchmark number chaser!
The Ryzen 7 5700G is a good choice if your system lacks a discrete GPU. As you can now use NootedRed.kext to boot macOS with the AMD Integrated GPU.
Reactions: HKPhysicist
